What waterblocks are there currently available for athlon 64's and fx's? I wanted to get the dtekcustoms kit but they dont have any waterblocks available
Danger Den also has the RBX block for the 64 and Opteron line of chips. The Item number is DDRBXA64 for $57 that comes with all mounting hardware and some extra stuff.
It seems to work fairly decent, mine runs at 44-45C when under a load in a room that is about 72F.
Why not meausre both temperatures in the same system? Having your room temp in fahrenheit and core temp in celsisus is so confusing!
Edit: Yeah, the danger den one is pretty good. The only bad thing is you can't stick a heatsink on top of it, because of the tubing. On some water blocks, the tubing is on the sides and the top is flat copper, you can put a Zalman 7000 on top to combine both worlds for best results.
