waterblock too heavy?
pwolfe
So I just installed my xspc water block on my 8800gt. It looks like the card is bent now. Its definately not cracked, but it seems to be bending downward on the side with the power connection. Did I damage this thing or is that normal? I cant boot it up and see because the rest of my wc components havent cleared us customs yet.
take the block off and try it with the heatsink
its probably just the weight, its fine, they've tested waterblocks with the products
just make sure not to push down on the card further or to weigh it down anymore, because that make cause problems
PCB can flex slightly
