**Waterblock for X850 XT***
Most any GPU only block will fit just fine. The X8xx series all have the same mounting holes. You might want to look at the new Swiftech MCW55 as well as the Maze4.
The Aqua Computer AquagraFX 6800 rev 2 cooler isn't that much more expensive at about $89. Cools both ram and GPU, has a floating GPU sink that eliminates GPU to RAM mismatches, fits both 800 and 850 cards whether they be AGP or PCI-e, and definitely has bling bling factor with its lighted Aqua Computer logo.
If you're looking for MAX performance, go with what Erasmus354 said........... :cool: Or even the PolarFlo blocks, any of the 3 will bring you top performance and OC's if that's what you're after....................... :eek:
