Waterblock for my gpu
Tom Mix
Hi, a bit of help required by this WC noob.
Which waterblock will fit a 9800 All-in-wonder?
Thanks in advance ;)
Ok, no responses. Let me ask it another way....
I'm looking to order a gpu block from here, and I notice that most of them say 'not all-in-wonder'. Why is this? Can I jimmy something to fit? Otherwise, which block will fit?
AIW cards have more 'stuff' on them. This makes them physically different than non-AIW cards.
I have a DD Maze4 on my BBATI 9800pro (non-AIW), and I'm very pleased with the overclock that I have; I plan on bumping it up some more as time goes on.
On a side note, when I took the stock HS+Fan off the card, it was only contacting half of the GPU die :eek:
I remember seeing pics here of the Swifty on an AIW card. He had to remove part of the base plate to clear a capacitor. Go check around the video card forums, it should be there somewhere, or in this forum.
