Waterblock base dimensions for 939
Disarray
I have ordered parts for a 939 system. I have to build my own water block because it has to be side inlet and I cannot find a single one for purchase. I will order copper stock online and would like to have it here when my system arives.
I need to know the length and width dimensions for a water block for a 939. I will order my stock piece based on this. Dimensions in inches prefered but I can convert mm if that is all you have. I will fabricate the block after everything is here so it doesnt have to be exact. Just looking for the nearest 1/4" so I can order my material without to much waste. Copper bar is expensive. Thanks
I have found the mounting holes are 3 1/2" (90 mm) apart. I still cannot find a dimesion perpedicular to the mounting holes.
