musicman_ace
- Oct 30, 2003
I am looking into buying a water cooling kit for a AMD64 system I'm putting together. Its just to make the PC quiet, I don't intend to overclock it for at least a year.
My question is what is OD and ID? Some vendors actually tell you that a waterblock is one of the two, some just say that it will fit a certain socket type. I'm fairly certain that all the components need to be one or the other, but I'd like to know what they mean and if there is a major difference.
Thanks everyone
Thanks everyone
