it is split in half perpendicular to the thickness. So with Black Ice GTX radiators, to get the best performance out of them, the inlet and the outlet is important.
has anyone measured to confirm this? in this configuration, compared to the reverse configuration, the outlet side performs better but the inlet side performs worse. so it's not that simple actually anyway this weekend i'm going to be working on an idealized theoretical model for radiator performance as a function of water flow rate, air flow rate, and radiator thickness/dimensions. it should then be possible to evaluate which orientation is more effective. hmmm found this:
http://martinsliquidlab.org/2012/06/08/hesmelaughs-radiator-sandwich-testing/
which seems to confirm what you said
haven't found anything in a few minutes of searching. i'm sure the result is in some textbook or paper but i think it's faster to just do it myselfHmm, before starting with theory it would be good to look into the available body of knowledge instead of inventing wheel again.
