Water or Air
cabanaboy38
Please help.
I am rebuilding my system and I currently run a Corsair H50. I also have a Mugen 002 B cooler sitting on my shelf and was thinking of going to Air cooling since I heard this cools better than the H50. or maybe I should go full blow water cooling. see signature for system only change will be a custom HAF 922 case that is under construction.
thanks:confused:
Watercooling will give you the option to cool your video card much better and less noise, aside the H50 and Mugen 2 are pretty close in term of performance. H50 will be a better choice for just the cpu if you don't want too much weight on the motherboard. Watercooling is more time consuming to maintain, so think whichever fits your need or wants.
