- Oct 23, 2007
My Rocketfish needs a 'tenant' and I've decided I will be trying water.
Right now the plans for the build are -
Q6600 (oc 3.6ghz+)
IP35 Pro
eVGA 9800GTX
8gigs Mushkin DDR2 800
Corsair TX750w
I was planning on getting a Swiftech Apogee GTX Extreme block for the Q6600 and a Swiftech MCW60-R block for the 9800GTX (assuming it fits, otherwise I'll get whatever does fit that just covers the G92 core).
I figured a single Swiftech MCP655 (regular or B version, not sure which to buy yet) would work ok.
My question is on the rad -
planning on doing a 3x120mm.
I know most people go with the Thermochill PA120.3 but then I saw (on Jab-tech) the Swiftech MCR320-QP-K for roughly $80 less. Now I'm not wanting to spend as little as possible, and I know the Thermochill is arguably the best rad out there temp wise. But what I am wondering is: given the components that I will be cooling (Q6600, 9800GTX), would the Thermochill be worth the extra $80 or will the temp difference be pretty low that the Swiftech MCR320 would be sufficient?
TIA
Q6600 (oc 3.6ghz+)
IP35 Pro
eVGA 9800GTX
Corsair TX750w
TIA
