Water Flow Direction Question?
bbowers12
I am getting ready to order a water cooled setup and have been doing some research. I am just going to cool the CPU. My question is how should the water flow from pump?
Should it be:
Reservoir to
Pump to
Radiator to
Water Block to
Reservoir
or does it need to go from
Reservoir to
Pump to
Water Block to
Radiator to
Reservoir
the block needs pressure so lot's of peeps like to run
pump
block
rad
rez
pump
block
rad
rez
the other advantage is the cooler water is also in the res which is the largest body of water, that can give you better cooling potential
:confused:
Run it so that your tubing has fewest sharp bends and looks how you like it. Order doesn't matter, water temp varies very little anywhere in the loop. The only thing you might want to consider is placing the res before the pump inlet, it has been suggested that this reduces the possibility of pump cavitation.
the above poster makes a good point.
I see
Res->Pump->Rad->block
very often....it also seems to flow in a system better that way with few bends. I have a SFF and that is how mine works.
