I'm in the process of revamping my Feeding Frenzy project and need some sources here in Florida or South East USA who can laser or water cut my Lian Li V2000b case. I need to cut openings for the bottom compartment (both side panels) with radiused corners as well as a much bigger opening to see into the upper compartment also with radiused corners.
I would like to use tempered glass to fit the openings so that the glass is flush with the outside case panel or perhaps 20-30 thousanths receded. To do this I will probably need a source than can do diamond CNC grinding as well.
