- Feb 24, 2005
Last night I changed the mobo in my system and when I was done, rehooked up the WC system. Now I run into some tempature issue.
With the old motherboard, I would only see a few degree C difference from when it was Idle to when it was under a heavy load.
With the new motherboard, under a load it increases by as much as 20 degree C.
There wasn't much thermal paste left on the cpu, but just enough to cover it. I am wondering if I should go out and get some new thermal paste and clean off the block and cpu and redo them. Yes?
And how tight should I make the block on the cpu itself? The block moves a very small ammount but should i get it to the point where it doesnt move at all and should I worry about damaging the CPU if I do?
