Ok well I have a lil extra cash and instea dof getting a new hd and hold off from a vid card ive decided to go water cooling.
I have a few questions does this mean I no longer can use my fan control?
Do I need a new case?
What all do I need??
This is a case I was looking at Now are these cases come water cooled or are they just built for water cooling if you add it?
http://www.xoxide.com/watcoolcas.html
Also here are some kits.....
http://www.xoxide.com/koolanceexos.html
http://www.xoxide.com/reserator.html
http://www.xoxide.com/koalex.html
What all do I need will these fit... What will I have to do..
My setup...
Case
Thermaltake Lanfire vm200 midtower
52x24x16x52x DVD Drive
8x16x24x DVDR/RW CD-Rom/DVD Drive
3.2 ghz P4 @ 3218.6 Mhz / 803.9 FSB
5700 Ultra 128 Mb / 128 bit
Dual Hardrives 120 GB maxtor Drive / 36 GB OS Drive
Gigabyte 8KNXP Motherboard
Dual Channel 3500 ram = 1 gb total
ThermalTake LCD Case with 6 fans Counting all of them.
Windows XP Pro
Thanks!!!!
My setup...
Case
Windows XP Pro
Thanks!!!!
