Carlosinfl
Loves the juice
- Sep 25, 2002
I've got a brand new build I'm finalizing and it's been 7 yrs since my last build. Currently my setup is:
- Corsair Obsidian 750D case (I could live in this thing)
- GIGABYTE Radeon R9 280X 3GB
- AMD FX-8350 Vishera 4.0GHz
- Mushkin Enhanced Blackline 32GB 240-Pin DDR3 1600
Obviously I've omitted a few components like SSD's and PSU which I think are transparent to my water cooling build. I really am looking to piece together something from www.performance-pcs.com. They've got complete kits which I think will be good however I'm not even remotely knowledge enough to make a educated purchase. Can you veterans please help me put something together?
What I need:
- CPU block for AMD AM3+
- GPU for R9 280X
- x2 or x3 120mm radiator
- pump / reservoir
- clamps / tubing
I'd like to use 1/2" ID - 3/4" OD tubing size. I'd appreciate any feedback about components / kits / suggestions.
Please don't bother commenting on my hardware selection in comparison to x. It's what I have and works for me.
What I need:
- GPU for R9 280X
- pump / reservoir
- clamps / tubing
