I am building my new system to use watercooling but I have a few questions. I'll outline what I plan on doing first before asking the questions.
I plan on using the following parts for the system. I am currently assuming a single loop
1 Heatkiller
1 Swiftech MCP655
1 Swiftech MCR320-QP-STACK
1 Koolance MB-EVX58CF (for NB/SB)
1 Koolance VID-NX285N (when it becomes available)
The rest like exactly what barbs/tubes/res I havent decided on yet.
1. Regarding waterblock materials, I know your not supposed to mix materials. However I am going to use a Heatkiller 3 for the CPU. My question is can I use Nickle coated copper parts problems w/o any problems? I am asking specifically because I am using an EVGA X58 SLI Classified and i would like to also cool the NB/SB with this http://www.koolance.com/water-cooling/product_info.php?product_id=827.
2. Is it worth water cooling RAM? I've read its not really but I just wanted to make sure that this still holds true with i7 OCing
3. How necessary is it to have separate loops for graphics card and CPU? I mean obviously its "best" but can i get away with a single loop without any significant reduction in maximum OCing potential?
4. Do i need to use a pump with speed controller, or can I just assume on at max is best? Can i use something like http://www.koolance.com/water-cooling/product_info.php?product_id=751 with the swiftech pump?
5. What diameter tubing is the best to go with?
To sum up the rest of the hardware
Coolermaster Cosmos S
Intel i7 920
EVGA GTX285 2GB
12GB Corsair Dominator
1 Heatkiller
1 Swiftech MCP655
Intel i7 920
EVGA GTX285 2GB
