Allright, I'm currently constructing a mod in which I am cutting a graphic out of acrylic, sandwiching it between two larger pieces of acrylic and then sealing the edges. I then plan on running water through this "box" which would surround that cut-out graphic with fluid. Let's just accept the fact that my custom acrylic box is leak proof and works no problem.
I wanted to set this in the top panel of my tower. However, when thinking this through I have come up with a problem/question. Since this custom acrylic box is going to be the highest point in my system, will that cause a problem with the reservoir. Such as, instead of draining the water level in my reservoir over time, it will drain the water level in this acrylic box?
