Water Cooling P182?
Carlosinfl
Loves the juice
I have an Antec P182 and a Black Ice Pro 120mm radiator. I was wondering if anyone has been able to mount a BIP radiator in the rear exhaust fan section? I thought I saw someone mount their BIP to the inside of the case where the rear fan exhaust is however I find that my BIP does not fit and conflicts where the I/O shield lip would be.
Any suggestions?
I have however mounted the exhaust fan and then the BIP to the exhaust fan but I wanted to do the other way around...
Thanks for any help!
Will it not fit there at all? If it will you could just mount it there by relocating the screw holes where they'll hold the rad in place even if it's not 100% lined up with the fan grill and be done with it. A bit of misalignment won't hurt anything on temps as long as it's not too terribly extreme.
Head to XS forums. Like many other cases, XS members have dissected the best way to mount/install a WC setup. It's a recent topic that's easily searched for.
BIP fit really well in my P180, tucked right in flush with the case wall. Just had to slot the existing case fan holes to fit to the rad's hole locations.
