Water cooling checklist:
speaking of being a noob, i guess it should be moved this to the water-cooling sub-forum
Ok i am a noob when it comes to water cooling, but i decided to give it a go, mainly because i can put the radiator in the window and blow the hot air outside in the summer.
and if i can get a few more mhz thats a bonus.
ill bring it inside in the winter or reverse the airflow.
anyways i have accumulated some water cooling stuff over the years from trades and so on, and want to make sure i order everything else i need.
what i have is a thermochill 120.2 radiator (with no barbs), a swifttech MCP655-b pump, a d-tek fusion CPU waterblock (which will fit my board, it has holes for lga775) and a swifttech water reservoir
I am going to run everything 1/2 inch since that is what size the pump uses.
what i have in my shopping cart is this. Please let me know if i have missed something or one of those items is crappy. (oh and i know i need hose clamps as well, ill get them from the hardware store)
Swiftech MCW60-R2 GPU Water Block for Most NVIDIA & ATI Video Cards 1/2 & 3/8 & 1/4 Barb Fittings
Swiftech Hydrx Water Additive Coolant 2 oz Bottle
Primochill Primoflex Pro LRT Black 1/2IN ID 3/4IN OD Tubing (10 Feet)
Bitspower 1/2IN High Flow Nickel Plated Thermochill G3/8 Barb Fittings (2 Pack)
and maybe a chipset block as well. i havent decided yet.
The system is an i7 920 on a P6T-SE with 12 GB OCZ reaper 1600 mildly overclocked to 3480Mhz which is the most i can get without increasing the voltage. xp64.
and a 8800GT video card (good enough for a couple of games i play and 3ds max)
The case is a Lian Li PC 05b which is very small, i will have just the blocks inside the case and build something to keep all the other stuff together with the radiator.
thank you for your time.
