Tooterfish
- May 16, 2011
Hi! This is my first post here although I've stopped by frequently through the years to read some of the threads. I'm confident that this is the place to be for awesome advice. I'm new to water cooling and need to cool a 990X and two GTX590's + Mobo (for looks mostly).
I have everything I need, blocks installed, but I haven't decided on a few essentials, including reservoir. I stumbled across a dual loop res at EK and it got me thinking, maybe a dual loop is a good idea in my case. Problem is I don't have much information about dual looping.
Is this essentially just two separate water cooling systems running on their own independent pumps, res's and rads? If so, does a dual loop res just act as a single unit with two water bays to save space?
Finally, is it necessary or will a single loop with a little extra pressure from two d5 pumps do the trick?
If I'm sounding a little confused it's because I'm still learning about the whole wc thing and would appreciate any general advice as well
Thanks!
Thanks!
