DFI Daishi said:kits like the bigwater.....they just don't deliver performance levels that i consider to be worthwhile.
well, i'm not going to say that it is anything stronger than an opinion, however when running an XP-90, XP-120 or a 7700AlCu will deliver similar results, i would say that it is just better to stick with air, as opposed to complicating life with a low-end watercooling kit.SpoogeMonkey said:Not that I was recommending the Big Water, but just pointing out that simple, quiet solutions are there if someone just wants to "try out water cooling".
SpoogeMonkey said:It all depends on what you're looking for. Do you want something cheap, silent, max cooling for [H] OC'ing, ease of use, just something to introduce you to WC'ing, looks, etc? For a beginner a quality kit will give you everything you need to get going....just add water. Obviously some kits are better than others, and there's a kit out there for each of the above mentioned aspects.
The Swiftech Apex kit is probably the best one out right now. The D-tek Flowmaster is another good option, as is the Danger Den Maze4. If a cheap, quiet hsf replacement is what you're after, the TT Big Water kit is worth a look. Just don't expect anything amazing out of it. If you just want something to plop on top of your case, check out the Koolance
units. And if Euro styling floats your boat, bust out the credit cards for some shiny new AquaComputer Gear.
Be sure to look at places like FrozenCpu, DangerDen, D-tekCustoms, and Jab-Tech to get an idea of whats out there.
Now if you don't mind, I'm going to bookmark this post so I don't end up typing it again![]()
Erasmus354 said:Also you dont have a CPU block in that loop, only a GPU block...
Bio-Hazard said:If you're going for max performance, I'd go with the Swiftech APEX kit and the GPU block of choice, you're not going to get better than that. ..................![]()
jhego said:hmm, looking from that pic, the right side of the slots are disabled due to blocking. My speaker wires connect to the soundblaster and its on the right side.
what a royal pita to plug things in...Erasmus354 said:The radbox provides ample space for most any connector to connect and have the wire bend out of the way. The only reason why that monitor cable wouldn't make it is because he is using an adaptor which doubles the length of the connector....remember now wires can bend they dont have to go in a straight line! (What a novel idea!)
hey, the radbox is there for people who don't want to cut into their case. no denying that there are tradeoffs in going that way with it, however as far as these things go, i think that it's not TOO bad of a deal.ryuji said:what a royal pita to plug things in...
GFreeman9 said:I have air cooling for my pc now a thermaltake big typhoon for the cpu and the zalman vf700cu for the gpu. How much money (estimated) would I have to spend if I wanted to build a water cooling system that is better than that?
I went to DangerDen.com and picked out these items:
12V DD-D5 Pump.................................74.95
Black Ice XtremeII Radiator...................57.99
Danger Den Dual 5 1/4" Bay Reservoir....31.95
Acetal Version MAZE4GPU...................65.44
Tygon 3603 Tubing 1/2" ID 3/4" OD..........2.80
Arctic Silver 5........................................7.29
Subtotal.............................................240.42
Total w/ Shipping.................................261.31
Would that be better than the setup I have now?
SpoogeMonkey said:Also, I think Alphakry is about to get the [H]er's a group deal on the apex kit....might be able to save a few more $'s.
apex definntely beats it so far as performance goes. as for ease of installation, the exos wins, though not by much. as for cost, the apex wins. as for looks, the exos probably wins, although that depends on personal taste, to some degree at least. noise? that depends on what you set the fans no the apex to. the apex can probably perform better, sound level per sound level, however i have not seen/read enough to make that anything more that a liklyhood.jhego said:if you guys were to pick, would you get the Apex Kit or the Koolance Exos-2?
Top Nurse said:Depends on what you are looking for as they have different design and performance goals. If you want ease of installability, good looks, and good cooling then take the Exos II. If looks isn't important and you are handy with tools and want good performance then go with the Apex kit. The main advantage to the Exos II is portability between cases. If you install the Apex kit then when you change cases you have a slight dilemma. Do you toss the case and remove the watercooling components or do you sell the whole case with the watercooling components? With the Exos II there is no problems in this regard as there are no modifications to the case whatsoever.
Could you please explain just how handy you have to be to beable to drill 2 holes i the back of your case to install the APEX. I don't know how hand you are, but my 10 year old daughter could install the APEX kit, but then again, she knows what she's doing.Top Nurse said:Depends on what you are looking for as they have different design and performance goals. If you want ease of installability, good looks, and good cooling then take the Exos II. If looks isn't important and you are handy with tools and want good performance then go with the Apex kit. The main advantage to the Exos II is portability between cases. If you install the Apex kit then when you change cases you have a slight dilemma. Do you toss the case and remove the watercooling components or do you sell the whole case with the watercooling components? With the Exos II there is no problems in this regard as there are no modifications to the case whatsoever.
SpoogeMonkey said:Just for comparison, add $53 for the tdx block, $20-$30 for 2 good fans, another $17 for tubing ($2.80/ft), $7.50 for clamps dd's clamps are $0.75/ea x 10, $5-$10 for water additive of choice, and another ~$7 for shipping.....your up to $400 for a setup that will probably cool just a bit less than the Apex kit $250
+ $65 for acetal maze4 or wait a week or 2 for the new Swiftech mcw55 gpu block to hit shelves.
BTW either setup will cool better than what you have now. And ideally will let you oc a bit more.
Erasmus354 said:You seem to be ignoring the fact that someone could do the same thing with the Apex that the Exos II does, by using the radbox and modifying a double PCI bracket you can put the APEX kit into a case without cutting it up at all.
but of course that would have ruined one of your arguments against the Apex so why even consider that. This is exactly the kind of convenient "white lie" that makes you and others (on the low and high flow side) look biased towards one device or another.
