Kezzerdrix777
- Jan 19, 2005
I got a LGA775 P4 3.4 Preshott and I want to bring down my Temps. I've been looking in to the Big Water Cooling kit from Thermaltake. Big Water
Now I want to mount this on the inside, but my case My Case does not have proper 120mm 92mm or 80mm fan mount on the back if the case. It has some stupid plastic clip for a 120mm fan. I've been thinking a while for a solution and I came up with I'll just mount the radiator to the 120mm fan on the clip. Now my question is fan sucking air through a radiator as effective as a fan blowing air through a radiator? If any one else has some installation advice or kit advice please let me know.
