Santasballz
- Jan 10, 2005
My first time, so plz go easy.
Everyone recommends testing the water cooling system first before installing it. so basically you set it up outside and let it run for 24 hours to make sure there is no leak....but WHAT DO YOU DO AFTER THAT? how exactly do u install it?
1) do you keep the WC system intact and try to install the waterblcok onto ur cpu,gpu
(seems kinda difficult with the tubes attached)
OR
2)take apart the system, drain out the water, install the waterblock, reattach the tubes and liquid.
both ways seem to be quite difficult. seems like as long as i pre-test the system i'll have to go trhough some difficult process to install it??
edit: the easiest way i see it, is to directly attach the blocks onto cpu,gpu, then install the WC in ur case, but that skips the testing process, which sounds pretty dangerous
OR
