water cooling in this case?
I think that would be almost impossible to contain everything inside the case. You would have to build some sort of external enclosure for the pump/rad, then, maybe.
its possible , look up the people who have shuttles an W/C em only thing that maybe outside the case is the Radiator (an thats a good thing) :)
you can do it, but most people will have to sacrafice the optical drive bay for radiator. There are really small pumps that like the Mag 12 or the MCP350 pump that ive seen people use also.
well i only need 1 hard drive nad a dvd burner so i'd have some free space in there and also fi you use WC do you still need a few fans to keep the case cool not just the cpu?
oh and how much is a good water cooling (for this case size ??) and do you still need fans for like the CASE itself oir how does it work im' new to watercooling.
