Water cooling: helps with dust?
Endeav
My only problems with PC's as of now have been of stuff burning because dust got in.
I was wondering if water cooling was a good solution to that.
Are case fans a + anyway or is water cooling a good solution in general?
Thanks.
Yes and no. Since I don't have a cpu fan, there is no build up of dust in that general area. However, you still need case fans in order to circulate the air around your case and dust will general get in your case. You can get some kind of filter behind those case fans so they will bring in and exhaust air but will prevent some of the dust from coming in. I don't use any filters and I still have to clean my case with a can of air every month. If your case is a carpet, move it up to your desk. Get some filters for those fans and clean the inside of your case regularly, then you shouldn't have too much trouble with dust.
Here is a recent threat about dust-proofing your case.
http://www.hardforum.com/showthread.php?t=1003676
I will be introducing a case with Air cleaner . like whats used in submarines when Conroe is released . Dust is a problem and I am attacking that problem.
You can cut down on most of the dust by having smart airflow through your case. If you have more fans bringing air in then out, then all you have to do is put dust filters on the fans bringing air in. That will remove most of the dust you would get into your case.
