water cooling hard drive in shuttle
Santasballz
is it possible, are there any hard drive water block that will fit in a shuttle p chasis?
or are there ANY hard drive cooling solutions in a shuttle P? the cpu and gpu are cooled fairly well...but hard drive burning to death.
most hard drive cooling solutions are made to be used in a 5 1/2" bay. You could design a custom waterblock, where do you have the hd in your shuttle, in one of the top 2 spots or in the 3.5" bay?
the p chasis has the hard drive on top.
i did find a hd water block for sell that uses 3 1/2", but since the hard drive is on top...will it work?
The P chassis has space for 3 harddrives, two on top and one in the 3.5 bay, if you found a block for a 3.5 bay you can move the HD there unless you already have the bay occupied with a floppy.
i can take out the floppy.
but the thing is, doesn't p chasis only have 1 3.5 bay? wouldn't the waterblock + hard drive take up 2 3.5bays? ( i am not sure)
anyway, here are the two possible blocks:
http://www.frozencpu.com/ex-blc-129.html
http://www.frozencpu.com/ex-blc-72.html
If You are using two top HDD mounts then You will not need to WC HDD's cause they are cooled with their own two fans.
MD
MD
yah, i was wondering about that. those 2 70mm fans seem pretty week :eek:
I'vw build SB81P ofr friend of mine and His HDDs are cool. Those fans aren't turning fast but definitly cool HDDs better then in G chassis series XPC's. Those are also small like 60 mili or even 50 mili. Still when touching top of a cover shuttle is cool. Also touching HDD's tells Me it's HDD's are cooled proper.
MD
