Water cooling for Shuttle SB65G2
there are no premade units, you'll have to go DIY. I reccomend an Eheim Compct 300 pump... it's slightly smaller than an AMD stock HSF, it'll fit anywhere. As a rad, place an 80mm on the outside of the rear exhaust, and the fan on the inside. Just add block, done :p
Put the fan behind the radiator, the consensus is that a fan pulling air through a rad improves cooling performance. Actually, test it yourself, it's not difficult to switch them around. Other than that, good luck and post pics please!!! Sounds very interesting.
I have no experience with the aforementioned eheim 300, but the pump I would recommend is the laing DDC, it is a 12v pump with tons of head and it is tiny to boot.
Do a search in the SFF forum. There are lots of members who have modded their SFF with some decent WC parts. Take a look at the new DD 12v pump that takes up very little space and seems perfect for a SFF setup..
