Ok I have gone over a ton of senerios and would just like to try this one last thread to narrow down my decision on what to do and what I need. Would appreciate if only "WC Guru's" post (IE: More then two WC build):
This is the list of what we want to WC on a Maximus Formula w/QX9650 overclocked to around 4.3GHz
CPU
NB
SB
Mosfets
dual 3870 X2's
I already know all the basic parts Im going to need and I also know that lots say that WCing some of these parts is not necessary... but lets put this all aside and say that we must WC these parts. So with this in mind and it was your job to do so and have the most efficent heat dissipation, what kind of setup would you have... what Im looking for is specifics like how many loops and what component would be best with what component and on what loop and in what order etc etc...
CPU
NB
SB
Mosfets
dual 3870 X2's
