Water Cooling/Case Project Finished
noteworthy
Update! 7-12-04 Picture links updated and case changed. Post #6 will have all the links. They should work without any bandwidth problems.
LMK what you think. Please comment :)
Old Post:
Just finished my new case.
Drilled 2 holes in the top and mounted a fedco 2-302 heatercore in the top. It was kinda hard to get the system primed but once it was going it is virtually silent. Temps with fans on high are 34C on load. With fans on low the load is 40C (Silent).
Maze 4 CPU
Maze 4 GPU
Fedco 2-302 Heatercore
Via Aqua 1300 Pump
Metal Clamps
1/2" ID Clearflex60 Tubing
Zerex Super Coolant/Anti-Corrosive Agent
Pictures are here...
Tried looking at the pictures ...
Sorry, this site is temporarily unavailable!
The web site you are trying to access has exceeded its allocated data transfer.
If you want me to host your pics, I can put them on my site, just PM me!
Well I decided to change it around again.
Here is the original layout: (unaccessible from the first post link now)
Original Setup
I don't like how the original had the back wall with a hole. Also the PSU was upside down. Wires were a mess and the fans above the heatercore are loud on full blast.
I tried this next: (looked better in my head)
Not Successful?!?
Then about two hours later I tore it apart and built it this way. Very similiar to the first way but better IMHO.
Pic1
Pic2
Pic3
Pic4
Do you think my hard drives will be okay that close to the pump? I'll get a new one in Wednesday and it'll be mounted about an inch away from the via aqua pump. I tried to make the cables neat. Looms help but it isn't enough. Tubing is really tight on everything. (no slack) What do you like? What could be better?
Thanks
It'll be perfectly fine. My MCP600 is 1cm(or less) close to my Raptor.
Thanks.... I'm thinking about making the front exaust and the top exaust... suck air in teh back grills.. less dust around there
