Water Cooling Build Check
Sidicas
Case: HAF 932
Reservoir: XSPC Dual-Bay Reservoir
Pump: Laing D5
Radiator #1: 120mm X 1 Black Ice SR1 (REAR mounted)
Radiator #2: 120mm X 3 Black Ice SR1 (TOP mounted)
Fans: 120mm x 4 (<1000 RPM)
GPU Blocks: DangerDen GTX 470 GPU Waterblock x 2
Fittings: Enzotech Compression Fittings for everything
Trying to make both my GTX 470s cool and quiet.
Will these rads mount in a HAF932?
I know the rear fan in a HAF932 is a 140mm, but I saw other people were mounting 120mm rads there so I figured a 140mm rad won't fit, correct?
Is there a conversion kit or something that would allow me to use the Laing D5 with 3/8" ID tubing? Do I even need to worry about that if the pump is going into the XSPC Pump/Reservoir dual-bay that has 2 x G1/4" and a fillport?
Yes, it will fit a 360rad inside the HAF932 and you can mount a 120rad on the rear as well because the rear fan is 140mm but it has a 120mm fan mounting holes.
I doubt you need to worry the pump going into the pump/res.
