Water cooling advice/suggestions?
THEpiGUY
EDIT: I didn't want to bump this thread up from the dead. Let me thank you all for your suggestions, but it turns out I'm not getting the kit. If you want me to explain, I will, but there's really no need unless you are all just incredibly curious. Cheers.
-THEpiGUY
What processor?
You can add another 120mm radiator, or even a 240mm radiator... and hang it off the back with what's called a "rad box."
The Black Ice Pro 240 works really well!
It only costs about 35$ too.
I second that... a 120x2 is a good idea for that loop using a radbox.
although I would stay away from that Watercool MO-RA 2 Core that was mentioned as its incredibly restrictive. The Cape CORA isnt any better... its passive, which isnt necessarily a bad thing just not the best idea if your looking for performance. It is aluminum however... In this day and age you shouldn't have any aluminum in the loop imo.
