Water Cooled SFF
fl4wless
Any good prebuilt watercooled SFFs out there? looking for something near silent.
My last 2 builds:
microfly w/ f-i90hd, e6600, zalman cnsp7700 and 7900gt w/ zalman cooler.
sd37p2 system w/ 7900gt zalman cooler
Both of which i found to be too loud...the microfly being worse.
I doubt watercooling will help that much unless you get one that is huge and fanless.
Figure out which fans are making the most noise...that is a good first step.
Watercooled will be louder. Trust me, I've built 3 water-cooled SFF boxes. Unless you go with an external kit, which to me defeats the whole purpose of SFF.
You can get a watercooled system with a single 120mm rad thats turned down, works great if you don't overclock. At stock settings it should be near silent if everything is watercooled.
my Qpack is pretty quiet, I have a PA120.1 with a Panaflo M1A turned down on a rheostat.
