Some users have recently had their accounts hijacked. It seems that the now defunct EVGA forums might have compromised your password there and seems many are using the same PW here. We would suggest you UPDATE YOUR PASSWORD and TURN ON 2FA for your account here to further secure it. None of the compromised accounts had 2FA turned on.
I just bought a kit and it came with coolant but in shipping the bottle was broken and about 1/3 of it leaked out. My question is this. can i just use water and some water wetter for cars. Will that be good enough? thanks.
Yes you can, make sure it is distilled water though.
And water wetter can do some nasty things to plastic, and can deposit a precipitate in your loop. Some regular antifreeze mixed 90/10 water/antifreeze would work just as well or better.
