water coolant dye
monk3y
I am adding some dye to my current loop, I currently am using a black/uv collant, I dont remember the brand off hand, but the color is fading and would like to add some black dye, is there anything I can get locally that I can add to make my coolant darker the wont have a negative effect on my loop.
I've tried a couple of those dyes and just am not impressed, i never really got what was advertised from any of them, no good UV so i'm sticking with the full product becuase i worried about the effects in my loop as well.
Feser is what i have seen doing good, but why not make it simple and using UV-hoses? then the dye is history and all the extra trouble it gives by fading and other stuff.
Feser fluid really is wicked... But the Dtek UV dyes are great too, as are the primochill non-UV dye bombs.
