im looking at a new water loop, to cool my cpu (q6600 OC as high as i can get it), motherboard and sli 9800gtx's when they come.
Im gonna use 2 triple rads and a dual, with a laing D5 pump.
What sort of cpu temp drops would i be able to get using a Water chiller such as this:
http://www.specialtech.co.uk/spshop/customer/product.php?productid=2396&cat=575&page=1
is it worth the money? or will standard water work just as well.
Also, can you use the loop with the chiller off?
Thanks
Thanks
