gclg2000 said:I'd like to try out (one day) a water chiller setup in an "automatic" style. Submerge the condensor in the reservoir at the same time. I bet the heat load would eventually hurt the compressor though.
gclg2000 said:woops...didn't know i was building a perpetual motion machine.![]()
You would have to have some type of cascade to do what i was saying, or an autocascade chiller.
Dankimus said:i've been doing ALOT of reading on this subject lately, and submerging the evap in a reservoir is old news. If you look around, running a tube in a tube, heat exchanger type desing, where the fluid flows thru a tube containing the evap tube seems to be the hot setup.
Soldier Prime said:actually there already is a perpetual motion machine...it looks like a fan with the blades but in the blades there are ball bearings and so when one bearing goes down it makes the beaing on the opposite side go up and so on...hence perpetual motion
