water box price check
doox00
I built this last year from an old case, my first time and I think it turned out ok. I am considering selling it as I have lost interest for the time being in water cooling and so on. I was wondering what you all think this box would be worth with a maze 4 gpu block thats on my 7900gt currently and a danger den tdx copper block thats on my s939 x2 cpu. Has the heater core, 2 cooler master clear lighted 120mm fans on it now, the eheim 1250 pump, 5.25" dd water res, mini atx power supply and about 5-6 feet of 1/2" clearflex 60 tube on water out side and the water in side. Plus it has high flow quick disconnects on the case, to easily remove the hoses without leaking, those alone cost me 50 bux for the set of 2.
any ideas what I should ask for all of this? with and without the blocks.
thanks all
only 150 for all the water cooling parts, 50 dollar quick disconnects.. the custom enclosure (top was chopped about 6" from the original case, custom side panels etc), heater core/shroud/fans etc? figured at least a couple hundred..ouch.
Well, lets take a look at each component.
TDX sells for 50$. You could get about 35 for it.
Maze4 sells for 45$. You could get about 30 for it.
Quick Connects 50$. You could get like 35 for them.
Heater core... No idea of the retail, but I bet you could get 25-30$
Maybe 15 for the res.
5$ for the fans...
I dont think many people would have use for the enclosure you've made.
thats about exactly 150$ You can't expect any more for the pieces than 80% of their retail...
yeah, plus who wants external WC... internal is much nicer... so price drop for that reason
I think you could get at lest $200. Your target customer would be someone looking for an external unit like a Koolance system which costs a lot and most likeley won't perform as good as your setup.
