Some users have recently had their accounts hijacked. It seems that the now defunct EVGA forums might have compromised your password there and seems many are using the same PW here. We would suggest you UPDATE YOUR PASSWORD and TURN ON 2FA for your account here to further secure it. None of the compromised accounts had 2FA turned on.
are there any additives that are completely clear?(to prevent algae growth) and can you mix UV dye and food coloring with additives safely?(together or seperatly?) and are there any non uv reactive dyes made for watercooling?
Theres plenty of dyes, uv and non out there. I think the main ingredient in most of them is food coloring..but I may be wrong. And I think Zerex makes a clear antifreeze, just check walmart/auto parts store.
