Ron1jed said:ya the shoutcast steams are always full!!!
jpmkm said:Short answer - if you are receiving cable channels without paying for cable then you are stealing service. Cable tv and cable internet are totally different services. You can't automagically receive cable tv over your cable modem.
yes, +1. I have Wide Open West, and when you get cable internet, the basic cable tv stations automatically work free with a splitter, and its legal. I have my cable modem and htpc hooked up on the same line. The HDTV and digital channels are seperate though on encryped data channeling where you need the cable box.Vile said:This is not necessarily true, at least over here... Cox advertises their Cable Internet service by promoting and allowing you to split the connection to a TV. Cable TV and Internet here are two different services indeed, however according to Cox, it is acceptable to split the connection from the cable modem and watch basic cable TV. The difference being that the paid service is expanded.
Ron1jed said:think it would work on time warer cable?
Vile said:Cox advertises their Cable Internet service by promoting and allowing you to split the connection to a TV
This works unless your cable company comes out and installs a filter inside the external cable box/interface. If they do you lose the channels. It's legal because it's not your fault they forgot to put it on. Most of the time if you start cable service and cancel it but keep the internet you will keep your channels. At some point someone will come out and install a filter but only if they audit the box. Otherwise they aren't going to go out of their way.w1retap said:yes, +1. I have Wide Open West, and when you get cable internet, the basic cable tv stations automatically work free with a splitter, and its legal. I have my cable modem and htpc hooked up on the same line. The HDTV and digital channels are seperate though on encryped data channeling where you need the cable box.
no, it comes free when you get internet.. basic cable costs nothing with internet subscription. It doesn't matter anyhow because i also have HD cable and digital cable in other rooms. I'm paying plenty in montly fees.ne1wantaride said:This works unless your cable company comes out and installs a filter inside the external cable box/interface. If they do you lose the channels. It's legal because it's not your fault they forgot to put it on. Most of the time if you start cable service and cancel it but keep the internet you will keep your channels. At some point someone will come out and install a filter but only if they audit the box. Otherwise they aren't going to go out of their way.
