wat case is this?
willing to be the whole pic is CGI
most monitors don't let the characters jump out of the screen
so is that what it was, this is what I have bought Xclio A380
ANd these are the final results of the whole thing,
:eek: check temps , onload
Idle
Man I was biting my nails every second it went through prime , in the end it was stable . :)
How it all started ,Click link
http://www.day187.f2s.com/phpBB2/viewtopic.php?p=120#120
It will slowly come together in the end. A380 has this huge 250mm fans , two of them
Noni said:
hehe ill take that bet, the 1st difference between the acer and nvidia screen is the frame is to big, 2nd the frame has a silver outline, 3rd the neck curves out from the frame and is too big, 3rd if you look closely on the pick you see a little blue light in the bottom right hand corner of the frame that is the on light which is exactly were it is on the dell next to the rest of the buttons.
it looks like a samsung to me. the little blue light in the bottom right gives it away.
