Waste Mystro's money
mystro
I've been out of the hardware game for almost two years now, quite content with my hardware of the time but I think it's time to upgrade.
I will be building a completely new machine and have allocated roughly $1000 (can go a little above) for completely new hardware which includes case, water cooling, video, cpu, mboard, and whatever else I may need
I'd like to build it relatively soonish or at least get started on it soon so if anyone can give me some advice on what I should buy, it would be greatly appreciated :)
If you're an Intel man, I would recommend either a 2.6C or a 2.8C. They are speedy and many overclock like sons of bitches.
For an AMD man, the 2500+ overclocks nicely and I love mine, but you might be looking for a little more horsepower.
For a video card, don't buy nvidia, all their new ones are a joke. Get a Radeon 9600xt or a 9700pro. Both can be had for $200 or less if you shop around.
I love my Antec case, and highly recommend them.
Lastly, I would recommend corsair or crucial RAM for something with good performance and good reliability.
I'll make no suggestions for mobos, haven't really been keeping up as of late.
*Me was fixing my bad gramer with da edite
Intel:
P4 2.4C (best over clocker)
Abit IC7-Max 3 or Asus P4C800-E deluxe (or something like that)
Mushkin Pc3500 RAM Level 2 1gb
ATi 9700 Pro
1 Boot HD (40~80GB) & 1 Storage HD (120~250GB)
Lite On DVD-ROM or DVD-R +/-
Lite On CD-RW 52x
Thermalright SLK-947U or SP-94 w/ Tornado (if sound is not a problem or for something a little more silent u can try a 80mm panaflo u1a or thermaltake 80mm smart fan with adjustable speeds)
Lian Li Case's are nice but that's my preference
Monitors are up to you I use a Samsung 753DF 17 in. mon and its fine for me.
AMD:
AMD Barton XP2500+
Asus A7N8X Deluxe rev. 2.0 or Abit NF7-S rev 2.0
Thermalright SLK-947U or SP-97 w/ same suggestions for fans Same set up for intel just different chips and mobo
I don't know much about W/C so someone might be able to help you there.
Power Supply Antec True 430 or TrueBlue 480 or Enermax 431w
all high quality psu's
These setup's i think are good for at least 2 years? Please correct me if i'm wrong. These setups are just IMO.
I've been seeing more and more benchmarks where the a64 smokes p4 in games. Armed with this I'm recommending strongly an a64. I will be using newegg for price quotes as they are the most reliable and sometimes cheapest. Piece of mind is worth a little extra.
A64 3200+ 1mb l2 cache :$ 270
Asus KV8 Deluxe - $145.99
Mushkin black lvl 1 dual pack pc 3500 2* 512mb - $199
Sapphire 9800 pro - $229
WD 120gb SATA 8mb cache -$107
Chieftec Dragon - $76
Enermax Noisetaker EG475-VE -$92
Lite-on Black 52x CDRW - $34
Floppy - $10
Total: $1164
For watercooling, the only kit I can wholehartedly recommend is this one: http://www.dtekcustoms.com/index.as...&ProdID=102&strVarSel=141,178,166&strCompare=
It comes with mountings for AMD and p4. I'm not sure if it fits onto A64's, but very little does at this point. Search around to find a way to fit the WW onto AMD 64 hardware. It shouldn't be too hard (I've seen someone use the A64 retention bracket to mount it).
Total (due to 10% savings for now at dtek) is $1344. I think this is a reasonable price for a top of the line rig.
Athlon64 definitely is the way to go until the Prescott overclocking results come in. Also, you may want to look into the BFG 9500 which can be had for well under 200 and the flashed to 5950U speeds.
Mid Range -- Athlon XP 2500 Barton, 512 mb 3500 ddr, DFI Lanparty nForce2, 9600 pro/xt
High End -- P4 2.4C / 2.8C / 3.0C, Abit IC7 Max3, 1 gig of 4000 ddr, Radeon 9800 pro/xt
OR
High End -- Athlon 64 3000+, Shuttle AN50R, 1 gig of ram, 9800 pro/xt.
SilverStone SST-TJ01 -$82
Asus K8V Deluxe -$159.99
Athlon 64 3000+ -$215
Corsair XMS 512MB DDR PC-3500 x2 -$282
Total $738.99
It's just a start but that should atleast give you some ideas. As for going with the A64, I think the [H] said it best:
On the gaming side of things, if you go back and look at where our Athlon64 3000+ landed in the benchmarks, it is hard to argue against this $200 CPU. In fact repeatedly, the A64 3000+ simply makes the Prescott and the rest of the Pentium 4 bunch look bad, even the Extreme Editions. If you are looking at building a gaming system today, the Athlon64 is very attractive.
