SeeThruHead
- Jan 31, 2012
So they essentially recreated the joystick.
That doesnt bring analogue to PC game movement, something console gaming has had for quite a long time.all you need is TFGH and some foot pedals if you want some kind of unique setup thats superior in every way to WASD.
I want mental inputs on both my heads. That way, I have it covered as my input has zero lag and can use my own, very personal joystick.
Thanks, I will be here all week. Tip your servers!
How is this not basically the same thing as the MS Sidewinder Strategic Commander that came out more than a decade ago?
http://www.youtube.com/watch?v=TWf7TCps5uU
your whole arm.
Some of their claims are questionable. Humans are pretty dextrous, yet they claim that larger motions are easier for humans to grapple with and that minute motions are extremely difficult.
Seems to me that no human would achieve 100 WPM+ typing speeds if our fingers were the useless appendages they seem to believe, and that's with our fingers needing to go all over the place to find the right keys. With WASD on a keyboard, your fingers are mostly stationary. The chance of hitting the wrong key? Minute.
Maybe it's a decent product, but I'm turned off by their claims. I don't think any of them hold any water.
Haha, pretty much.. it's a short joystick.
Those are also two very different types of input devices. Joypad/joystick response is integrating (in most implementations), whereas mouse response is non-integrating. This doesn't appear to be significantly different from a keyboard with respect to forward/back/side-to-side movement.That's why it's easier for people to aim quickly and fine with a mouse(gross motor skill) vs aiming with their thumb using ai joystick (fine motor skill).
You mean your post? I agree.Wow this is dumb
