"Warning: write cache enabled, data corruption may occur."
Elledan
[H]ard|DCer of the Month - April 2010
Over the past few months I've constantly seen this message appear in the event log on a W2k workstation:
"The driver detected that the device \Device\Harddisk2\DR2 has its write cache enabled. Data corruption may occur. "
Then, occasionally:
"An error was detected on device \Device\Harddisk2\DR2 during a paging operation. "
The HDD in question is a Maxtor 120 GB, connected to the onboard Promise RAID controller (set to ATA). The swap file is on a partition on this HDD.
I've tried to disable the write cache, but found that this option is greyed out in the drive's properties sheet.
Is there a way to disable the write cache, or is Windows going crazy?
The write cache is only really an issue if you lose power while writing to the disk - I wouldn't give it much thought.
The "An error was detected on device \Device\Harddisk2\DR2 during a paging operation." is a much greater concern... It seems to indicate that you've either got -really- bad drivers, a hardware conflict or some bad hardware (maybe cabling?) somewhere...
and that it would be a good idea to start troubleshooting the issue
and ruling out the possible causes
Corruption 101
not that you havent seen that link a half dozen times :p
Corruption 101
I think you just enjoy whacking people over the head with your links ;)
Bad cabling/EMI might be an issue, as this HDD is wedged in the top 5.25" bay (because the case can only take 2 HDDs after you've filled the exposed 3.5" bays). The cable is not routed in a manner which I'm totally comfortable with.
As I'm upgrading this system anyway, I might just move everything to a new case, which actually was meant for more than 2 HDDs.
Thanks for the help :)
[..] -really- bad drivers [..]
Well, this _is_ Promise we're talking about :p
