I
Ice Czar
Guest
I have for many months now been passing out the information that SATA is a more reliable form of data transfer than Parallel ATA
and the following has been called to my attention (by CityK), that while theoretically that is true, in implementation it may not be,
if fact it could be worse
SATA Implementation Cautions @ ATA-ATAPI.com
Regarding the theoretical benefits (and real PATA issues)
SATA and the 7 Deadly Sins of Parallel ATA
ATA Not So Frequently Asked Questions
as of right now, Im unaware of any shielded SATA cables
youd have to shield them yourself, I'll post some info on that later.
Id read that top article and follow those instructions carefully
in addition Hale offers a Demo version of ATACT to check the data integrity, and a soon as I can figue out how to actually run it
I'll post a tutorial
PS anyone know how to read a .UG file?
If you are setting up a system using SATA here are some things you must be aware of:
* DO NOT operate SATA devices outside of a sealed system unit. DO NOT operate SATA devices from a power supply that is not the system unit's power supply.
* DO NOT tie wrap SATA cables together. DO NOT put sharp bends in SATA cables. DO NOT route SATA cables near PATA cables. Avoid placing SATA devices close to each other such that the SATA cable connectors are close to each other.
* DO NOT operate a radio transmitter (such as a cell phone) near an exposed SATA cable or device.
Why all these warning? The basic problem is the SATA cable connector is not shielded. This has to be the number one most stupid thing that has been done in the SATA world.
