From the AnandTech website, an update to their earlier review on the DFI nForce4 Ultra board:
So the moral of the story is, if you were hot and heavy for the DFI Ultra because of the possible back-door SLI, you may want to rethink your decision.
Of course, there are plenty of other merits that could make the DFI the nForce4 Ultra your board of choice regardless...
UPDATE 2/05/2005: nVidia has acted to prevent, or at least make it more difficult, to mod the Ultra board to SLI. First, DFI has advised us, and posted on their website, that they will NOT sell the SLI bridge to buyers of the Ultra board. Second, nVidia has advised us that future shipments of the Ultra chipset have been modified so that the mod to SLI will no longer be possible. An additional side effect of this second action is that the "Dual Video" mode, which performs at about 90% of SLI performance levels, will only work with nVidia SLI drivers 66.75 or earlier. If you do a quick check of web driver postings you will see it is now very difficult to find 66.75 drivers. With a chipset modded to SLI the "Dual Video" mode worked through 70.xx versions of the nVidia driver. nVidia also made it clear they will continue to make driver changes to prevent functioning of any "non-standard" (8X/8X) operation of their SLI driver. This also throws into question whether the VIA "dual graphics" mode on the 894 Pro chipset will ever work with nVidia graphics cards. If you are interested in the current UT Ultra-D we suggest you buy one now if you can find it. Future versions of the UT Ultra-D will not have the same capabilities as a result of these actions.
