Warning on 6950 power cord instructions
pillbub
I purchased a HD6950 and the instructions insist to not mixmatch power connectors. There are 2 plug-ins and I only have 1 splitter and 1 pci cable, theres like figures with big X Do not do this images but I dont have 2 pci cables or 2 splitters.
Are they being overcautious or is it ok to use 1 splitter and one straight cord how big a problem exactly is this..thanks.
In an ideal world it's not good to power it from the same source, but if your PSU cost less then $60 chances are they lied and you've only got one 12V rail anyway (so there is just a splitter hidden in the PSU). On the flipside if you bought a really good PSU (does the name Seasonic appear on it?) it will probably make no difference because both rails are rock solid and overengineered to the point that you can go 25% over the PSUs rating and still be getting cleaner power then a 'SuperPower 700W*'
So to answer your question, lots of video cards say to power from seperate rails, but since most of us are intentionally or unintentionally powering from one it can't be that bad.
*700W is just the trade name, actual rating is 230W.
I think I may not have been clear, although I have a feeling the answer is the same.
It's not 1 splitter going into both of the video card plugs. The video card has 2 plugins and I have one 6pin to 6pin straight cord for one of the outlets..and for the second plugin I have to use a splitter going from the 4pin to 3 pin and back out to a 6 (sorry dont know the name of the splitter I could check if it matters).
What PSU do you have? Chances are that if you have to do all that to connect the damn card, you don't have a PSU that will be able to run it. I would suggest you get a 550w+ psu from a quality manufacturer and you will be just fine.
Its a corsair HX 520 and it came with 2 pci cords but i lost the unneeded one Im going to buy another pci cord from best buy today to play it safe.
edit: I believe theyre called pce cords I noobed it up.
It sounds like you're talking about a 4-pin to PCI-E adapter, not a splitter. If that's the case, you can use it safely.
Well since it requires 2 power cables one socket would recieve a normal PCI-E cable and the other socket would be a 4-pin adapter since I only have 1 of each.
Posting in another thread someone replied it might not be a wise idea to have 2 different cables leading to each socket because the wires cause different voltage to the seperate sockets.
PCI-E cables are only 5 bucks at New Egg so I'm expecting similar prices at Best Buy,
You can't buy a PCI-E cable for your PSU. Just use the molex to PCI-E adapter. It's perfectly safe.
You wont be able to find that cable at a local store as its not a standard cable. You'll probably have to contact the manufacturer. Like Zero said, just use a molex to pci-e
A 4 pin molex to PCIe adapter will work while you contact corsair for a replacement.
what do you mean "splitter going from the 4pin to 3 pin and back out to a 6" ? you aren't adapting clear down to a fan header and back up are you?
Nope, when I say 4 pin i think i mean 5 there is actually 5 prongs but if you peer into prongs theres only 4 of them with metal pins in them and one is empty.
But my psu has two '6 pin outlets' (pci-e cable) and five '4pin outlets'. I have one of the video cards outlets supplied by going straight into the 6pin one, but for the other power outlet I have to connect an adapter from the 5 pin on the psu which splits off into two 4 pins, which I plug into another 4pin splitter and that has a 6pin end on it that plugs into the second card slot.
Maybe no 100% load stress testing till the replacement cable comes from Corsair...I mean, it should work fine and you should fire it up and enjoy it, but with adapters strung all across the case maybe no bitcoin mining eh?
It will work just fine, don't worry about it.
Don't use those weird terms. A molex connector (4-pin) is a molex connector, regardless of how many cables are actually connected to it. The reason why it uses only 3 out of the 4 is because PCI-E only uses 12v, while the molex connector has both 12v and 5v. The 5v is left unconnected. You wouldn't want 5v going into your graphics card, would you?
I just want to be clear, I am not disagreeing with Tsumi, it will work fine.
If it was me I would work to adapt over with 12 wires before running the thing 100% 24-7...that's just me.
