"Warning CPU has Changed" Message
Gooey_GUI
A newly built PC with a Floppy drive error (40) that is followed by a "Warning CPU has changed" error message appeared after the memory count and CPU post. The BIOS is unavailable beyond that. It offers "Press Delete", but no response when that is pressed.
The motherboard is new, but the AMD 2200 is old. It was last known to be working until the the mainboard of the old system slowly died with IO errors. The keyboard and mouse stopped working. The boots following did allow Windows to come up a few times until there wasn't anything but the BIOS screen. Then, even that wouldn't come up. I replaced the battery and the PSU with new ones and it still wouldn't post. That's why I chose a new mobo.
Could the new mobo be faulty? After all, if the CPU was bad then the initial boot messages of the new system would not come up at all would it? I tried to bypass the floppy problem by not having a floppy cable installed in order to obviate the floppy error all together.
:confused:
the floppy cable dosnt really matter...
try to unplug all your drives..you might be making it freese case of a master and slave problem...laod it up with just video and keyboard connected...and no DVD HDD connected to mobo..and then as quick as you can try to get in to the bios.....
