Warm ? Proliant ML110G7 $423
/dev/null
Link
Use coupon code BLKNOVHPP
HP Link
Specs:
E3-1220
Pci-e x16 slot
pci-e x8 slot (@x4) (qty 2)
pci-e x4 slot (qty 1)
2GB ram
no hard drives (4 max)
2 lan ports!
Out of band management!
1 year next biz day on-site support.
It looks like the proc goes for about $210 or so and a somewhat decent board is $150'ish+ so you are really paying about $40 for the warranty, out of band management, ram and power supply.
Although you've entered a valid promo code BLKNOVHPP, your order does not currently meet the code's usage criteria.
:confused:
Some things to keep in mind with this system:
-If you want to use your own SATA hard drive you will need special caddy's that cost about $20+ each.
-This comes with the E1220 processor which does not support HyperThreading. You'd have to get to the E1230 before that is available.
Good points.
I think the E1220 is similar to the i5-2400/2500.
The other cool thing is that this proc supports ECC & vt-d (for device passthrough to VM guests). ANyone know if the motherboard chipset supports vt-d as well?
