Warm? Pentium G2120 @ Amazon for $78
/dev/null
Link
$100 @ newegg
$113 @ tigerdirect
Yeah looks good. Looks like amazon's low price has forced others down on their site as well. A ton of sellers are cheaper than newegg/TD
Oh whatever happened to the old NE with deals-a-plenty...
Why are these chips so expensive? I remember getting my e5200 for like $50 or $60 and it could actually overclock.
$78 isn't that expensive... You can get a celeron for $50 if you think this is too much. There is no point in complaining over not being able to overclock, that boat sailed over 2 years ago.
Or you can go amd and get worse single thread performance, hotter, and higher power consumption for the same price... There is a reason it is priced what it is... people will pay for it.
I think it's because the single threaded performance is fantastic. I"m pretty sure the G2120 is like 20-30% higher in single threaded than a 1090T (IIRC...i was looking at a bunch of stuff on cpubenchmark.net last night & could be mistaken).
Why does everyone think that these chips don't overclock? Not sure about this model in particular but I was pleasantly surprised that my cheap non-k system pull i7-2600 bought off ebay had a selectable multi up to 42 and then you can tweak the FSB to get pretty close to the 5Ghz or so of the K series. They may not have a totally open mulitplier but still plenty of options and performance for overclockers.
This is probably for chips which have turbo mode, wherein you can lock the clock on some boards at the turbo speed
They got their name out there. Now they're making money-a-plenty and don't need to scavenge for customers anymore.
Maybe, but a year ago I would not have even looked at amazon or TD before buying on NE. Now, I get more stuff from amazon
I highly recommend this chip for entry level gamers. I built my cousin's rig a year back using these spec's and it's going through Skyrim even with 1K texture mods and ENB at 25-40 FPS outdoors, 40-60 FPS indoors.
Intel Pentium G2120 3.1GHz $108.80
ASRock H61M-VS LGA 1155 $49.99
ASUS 6870 [H] Used $130.00
G.SKILL Ripjaws Series 8GB (2 x 4GB) $29.99
CORSAIR Builder Series CX500 $49.99
