Warm: Dell 2707WFP $899
Great deal. I got my 2707 last August for ~$940 thanks to a coupon and this is the first deal I've seen to beat that price. You definitely pay for the pretty aesthetics and extra 3' over the 2407/8, but I couldn't be more satisfied with mine. The slightly larger pixel pitch, PERFECT 1080p 1:1 scaling for DVI and VGA inputs (PS3 and 360 are a sight to behold on this thing), and great color gamut make it easy for me to recommend this monitor to anyone other than the photographer / artist who insists on an S-IPS panel, which this is not. The slight color shift typical of an S-PVA panel is there if you REALLY look for it (with a test image designed to emphasize it), but otherwise I could find nothing to fault this monitor for. I know some people have complained of input lag with this monitor, but I havn't noticed any at all playing everything from Crysis to Guitar Hero. If you're trying to decide between this and a 26' S-IPS (eg. Planar), I would choose the 2707 if you want a monitor that functions as something more than just a PC display.
This monitor is great except for the color shift...If you move your head a few inches to the right the left edge of the screen loses alot of contrast. It takes awhile to get used to if you are coming from an S-IPS panel like I did but now that i've adjusted and stopped shifting my head to the right purposely to "see if the color shift somehow magically disappeared" I am very happy overall.
The best feature of this monitor is the pixel pitch. You can actually read text on webpages versus the pixel pitch of a 1920x1200 24" monitor which gave me massive migraines while surfing the web. IMO 1900x1200 on a 27" monitor is the absolute perfect size! Highly recommend this monitor just be aware the color shift will bother you for awhile until you stop purposely making it happen by shifting your head left and right.
Cheers
