Warm? -- Dell 24" WS $299 + FS
All the Dell monitors are 30%-33% off currently if going through SMB.
That's the cheap 24"; the 2408WFP is superior ($619 today but sometimes they will cut you a deal when you call).
-PP
been toying with the idea of getting a 24", any [H] members have this monitor?
Lukewarm indeed. If price is your guide then yeah its a decent value. But if you're going to fork over $300 why not spend a few bucks more and get something really worth it.
is this a crappy monitor?
It is a TN panel. Not necessarily bad so long as you know what you are getting with that type of monitor. Personally I won't buy anything that isn't an S-IPS of some kind.
i haven't written off TN panels completely yet. the only comparison i've been able to make was a cheap Velocity Micro TN against my relatively expensive Gateway S-PVA panel. the Velocity Micro TN looked dull and washed out compared to my Gateway, but i figure that's hardly a fair comparison ($140 panel against a $450 panel). there has to be a quality TN out there, right?
Those cheap Dell monitors suck ass. We had a few of the 22 inchers in at my last job before I quite and everyone hated them so much, they went right back to Dell. Horrible color accuracy (impossible to calibrate), viewing angles made it impossible to get a consistant picture from top to bottom sitting right in front of the damn thing, flickering, greenish whites... I could go on. I would advise that you get what you pay for, especially with Dell.
I have both and agreed. That monitor blows. I only use it for gaming and it is "ok" at best.
The 2408WFP is worth the extra money IMHO.
Correct. Not all TN are poor. You just kinda have to know the limitations and see for yourself. It can vary a lot even from the same manufacturer. I've seen some gorgeous TN's from Samsung, HannsG and Acer and in turn some rather washed out and heavy backlight bleeders from those same three.
We had some cheap 19" Dell panels. I'm not sure what panel they actually used but the input lag was horrible and we had tons of them with dead and stuck pixels. Utter crap in my opinion. My Dell 3007WFP has been nothing but goodness from day one. You do get what you pay for. Especially with a Dell.
Are the 2408s actually better than the 2407s? I own a 2407 Rev. A03 or 4, but I'm not paying $600+ for a 24" broken monitor when I can get a 37" WH monitor for the same price or less.
The 6-bit per color thing really kills this monitor. Everything has banding. Viewing angle is pretty ghastly too. Anything outside of a couple inches off center results in pink sides.
